92' stuck in 1st gear
darn gearbox is stuck in 1st gear. I can use the clutch and drive my bucket around in 1st, but it will not move out of that gear. I've saw more than a few "stuck in gear" posts in the Porsche forums (ZF boxes)..
Anybody have any ideas?? |
Does the shifter move at all or is it locked up in the 1St position all of the time as well?
Bugger this for a joke... |
Basically, it's stuck in first gear. It does move left to right about 1"- 1 1/2", and a little front to back. It's jammed.
I was changing the wheels on my car when this happened. I left the shifter in second, brake on, and then jacked up the rear end. I wanted to rotate the hubs, so I tried to push the shifter forward into nuetral. It seemed to already be stuck in second gear, I forced it out of second (and presumably into first instead) with the e-brake on the whole time.. I'm guessing there was some torsional force in play while it was in second with the e-brake on. When I force it out of gear, it must have caught first somehow. I'm going to remove the tranny and poke around abit. I already tried rocking the car trying to move the shifter to no avail..
