Headlight Eyebrow Trim
Has anyone attempted this little upper headlight trim? It's hard to tell how well they will hold up to the elements, & stay secure just using adhesive strips. Contemplating getting a pair painted, but not sure if they are gonna stay secure during a Chicago winter. Anything bad about removing the NA headlight dimple on stock US stuff so it will fit?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
I think as long it is prepped and painted well you should have no probs. as far as keeping them one maybe 3M double sided tape.
Yeah, 3M makes a 'body trim' adhesive strip that is seriously tough, sticky stuff... that'll hold those on there no problem.
I've considered adding some eyebrows to my ride, but not sure of the end look. You'll have to post some pics when you are done, Supe. |
