clicking
depends where the clicking is comming from, if its from the head its a lifter, those are bloody expensive too, and whatever you do dont get after market ones, or OEM spec ones cause theyre soft, the odd one works but your best bet is the stock ones, they hard as hell and wont break, the aftermarket and OEM spec ones are just plain ****ty, period. and well if its comming from your block park the car NOW!!!!!!!! its a loose connecting rod and its going to wack its way right through your block and then your going to be proper F__KED! so i hope that helps, o and it also might be coming from your exhaust a leaky header gasket will do it, every time that cylinder ignights and lets the exhaust out it will make a clicking noise. hope this helps.
mike
Member of the: 3rd Pedal Club Member of the: 200,000+ Mile Club Member of the: drove 21 straight hours for fun Club Member of the: drove 8000 km in a week Club |
