EGO O2 sensor 1 replacement
I have a check eng. light and the code came up 1221, which
I believe is EGO O2 sensor1 needing replacement. Is this a very difficult job, and how can I turn off the "check eng" Light? Thanks very much. It is a bmw 1994 325I |
Typically, changing them is easy... What car is it for....
what year? the 318 or 325 (i.e., the I4 or the I6?)?
Thanks for the reply. It is a 94 bmw 325i.
sorry for not including that info |
Replacing them is sometimes a major PITA due to the fact there is little room to access the O2 sensor plus they are quite often very tight. It's worth a try, but I would suggest having the correct socket etc........and a long breaker bar.
| All times are GMT -8. The time now is 10:16 AM. |
