Send a message via ICQ to kingsiang Send a message via Yahoo to kingsiang
Question Abient temperature anyone?
hi, have any of you guys ever had this problem? its on my 1995 e36 m3, well in the OBD, the temperature shows to be -37 degress celcius. I changed the sensor and it shows -35 degrees celcius. Does anyone happen to know what could be wrong? help is very much appreciated. thanks.
Old 02-13-2005, 09:08 PM
Send a message via AIM to Trevor
I have the same problem, (among others)
Bump
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-15-2005, 06:15 PM
Wow... nobody ever helps in this forum? been trying to find a professional forum to get some advice... in vail all forums seems to be same. All they know is pretty much changing head lights... blubs etc.... Sigh....
Old 02-16-2005, 08:22 AM
i have the same problem. the new sensor is supposed to fix the 10 dings per day notifying you it is freezing outside.
Old 02-21-2005, 10:51 PM
frankc's Avatar
Does the temperature ever change, or is it always fixed at -37?
I don't know if this applies, and given that there are few of you experiencing the same problem, maybe not, but I had a similar issue on my wife's Town&Country. Replaced the sensor and the temp was still way off (and fixed). I ended up tracing the wiring and found a break in one of the wires so there was an open circuit (infinite resistance). Fixed that and it's been working fine ever since.
If you have the Bentley manual, trace the wiring diagram for the sensor to see if there is a connector along the way. Perhaps the contacts are a bit corroded and any little variation in resistance will show up as a big temperature change.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-23-2005, 08:05 PM
right... thanks... i thought so too. cause when i installed the new sensor, it shows -35 not -37 which means there must be some resistance somewhere. but i dont have time to trace em now. talking about rust i doubt that mine is due to rust. Well ill find out and let u guys know too. thanks for the help.
Old 02-24-2005, 08:36 AM
Temperature sender problems
My sender was missing, the display showing -37 and after fitting the sender it showed -36.2 but I left it over night and the next day it was working fine. I think it takes a while for the computer to re-calibrate it self.
http://www.parengstrom.com/bmw.htm
Old 03-07-2005, 12:19 PM
LeRoux Strydom's Avatar
What you are seeing is typical of an open circuit somewhere in the temp measurement wiring. Trace the wiring from the sensor to the dash module, you'll be sure to find a break in the wiring or an unplugged connector somewhere (most likely).
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 03-15-2005, 12:55 AM
agreed. oxidation on the plug perhaps too.
1991 nissan 240sx
sr20det cp pistons, eagle rods, 740cc inj, k3t turbo, jwt s4 cams, lots of duct tape, GReddy headgasket
Old 03-18-2005, 08:17 AM
