supertack's Avatar
Fog Light Replacement
A few days ago (during a typical Chicago March snow storm), I noticed that my fog lights wouldn't go on. At first I thought it was just a burned out bulb, but when I realized both fogs were out, I figured there had to be more to it. When I looked at the lens of the fogs, I discovered that the drivers side had a pretty substantial crack 'spider webbing' across it. I checked the fuse, to find #15 was fried. When I put a new fuse in, both fogs came back on, but the crack lens created an unsightly issue.
The question is two fold. Is there a replacement lens for the oem fogs, or do I need to purchase the whole thing?
Also, how do I release the fog from the mounting bracket on a stock e36 bumper? I've seen a pic of releasing it on an M3 converted bumper (slot in air duct), but I can't seem to locate an opening through the lower grates on my stock bumper.
Thanks.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 03-17-2005, 05:27 AM
I think pelican sells just the lenses for the fogs. Also, they might have a tech article on how to change them. I've always seen the lense popped out with a screwdriver from the outside. this seems to be efficient.
Old 03-17-2005, 09:31 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
i just changed mine out. The lenses are available on ebay for about $50 each. As far as changing them, I found getting under the car, removing the small plastic undertray on each side easier than trying to pry them out from the outside. you will see the lenses will pop out of the housing quite easily. there is a clip on one side of the housing and hinged on the other. Maybe a 20 minute job for both sides all together. A lot easier than I was expecting.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-18-2005, 12:30 AM
supertack's Avatar
Yah, I found the slot to stick the screw driver through the lower grate today.
$50?? That sounds expensive for one little piece of glass.
97 328is
Old 03-18-2005, 04:25 AM
dboyles's Avatar
$50 does sound extremely high for just a lens, especially considering you can get an entire one-side assembly for that much.
The Pelican link for the lenses is here, but the non-Euro lenses are out of stock, and probably too expensive anyway. Which is too bad, since my passenger fog light lens is cracked.
Old 03-20-2005, 01:24 PM
supertack's Avatar
Yah, I contacted Pelican about those 'out of stock' replacements. They arn't even sure if they will continue to carry them. Kinda sucks cause they seemed like a nice alternative.
97 328is
Old 03-21-2005, 05:03 AM
blkongry's Avatar
Is this what you are looking for?? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7962912602&category=33710&sspagename=WDVW
Old 03-21-2005, 11:02 AM
stupenal's Avatar
i find it actually easier to just unbolt the bumper. takes about 10 minutes, you get pretty good at it after awhile.
as for the replacement, you should buy stongard to prevent rock chips from damaging your new lense. It shouldnt be more than $20. I know some people put on yellow french fog film (www.lamin-x.com) to give it that Euro look. Personally I think it looks good only on black e36s with m3 front bumpers.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 03-21-2005, 04:59 PM
dboyles's Avatar
That is what I'm looking for. For $12.50, it's worth a shot.
Thanks!
Old 03-21-2005, 05:34 PM
supertack's Avatar
Yah Boyles, I thought I had ya beat. I went to a max of $20, & some idiot paid $38 for those two lens'. I mean, it's a great alternative for broken glass, but $38??! With the $5 shipping, that's pretty pricey plasic. It's not like your gettin' the whole frickin' light. Some folks simply amaze.
97 328is
Old 03-29-2005, 05:13 PM
blkongry's Avatar
You ought to drop that seller a line and ask if he'll sell you a pair for... well, what ever you want to drop on some plastic lenses... where he had one pair, I'm sure he has another.
Old 03-29-2005, 09:44 PM
dboyles's Avatar
Yep, after I first got outbid, I set up a snipe for like $21.52. I was amazed at the final selling price. I think I'll buy an entire new lamp assembly for $40, rather than a couple of replacement lenses for about the same price.
If I was the seller and I had another pair, I'd be putting them up on eBay to let them sell for $40-ish rather than selling them to someone for $20-ish.
Old 03-30-2005, 01:48 PM
blkongry's Avatar
Yeah, but something that goes for $40ish once, doesn't mean it will go for that again. I've seen a seller punt an item for half what it went for in the auction before... that's the beauty of Ebay. Something is only worth what someone is willing to pay for it at that time and place. If he's got a big stock of these lenses, it's in his best interest to make a solid sale. The next set may go for $2.00..... but not if you two are on there :-P
Old 03-30-2005, 02:39 PM
supertack's Avatar
I use to get pissed when I went to bid on something that was currently low, but the high bidder had an idiotic max. Now I just keep bidding in small increments up to my max, just so the joker who bid the moon doesn't get it for cheap. I figure, if your gonna be an ass hole with your bids, you might as well have to fork out the cash.
97 328is
Old 04-01-2005, 01:34 PM
Send a message via ICQ to BMR MAN Send a message via AIM to BMR MAN Send a message via Yahoo to BMR MAN
The cracking was probably due to the lamps being cold, then heating up, then being extremely cold again. You should only use fogs when you need them, despite them looking good. I would check around for better pricing. I've seen stock replacement assemblies range from 40-80. Thats per not pair. Good luck
Matt
1997 BMW M3
"Time cannot be influenced by mankind. It gives each of us a beginning and an end. And this makes us question the significance of what comes between. But if you can create something time cannot erode, something which ignores the eccentricities of particular eras or moments... something that is truly timeless, this is the ultimate victory."
- Dr. Ing. h.c.F Porsche
Old 04-03-2005, 01:41 AM
supertack's Avatar
Good call BMR. I use to leave the fogs engaged 24/7, so when I turned on my headlights the fogs would come on. The crack (and subsequent blown fuse) must have happened some time over the winter, but I didn't notice it until last month.
I even thought maybe the fog was impacted while driving by bulit up snow ruts during a winter storm. Im not sure if the impact shorted the fuse, or the crack led to the short. Either way, I leave them off now unless I need em.
97 328is
Old 04-03-2005, 09:42 AM
