Tire size for E36?
Will these sizes fit for my 92 E36 325i? 265/40ZR17 on the rear and 245/45ZR17 on the front?
Old 04-22-2005, 08:23 PM
blkongry's Avatar
Depends on your wheel offset and if your car is lowered or not. Those are pretty wide tires, but they may just clear (I think the fronts will clear). What you have to do is actually get up under the rear wheel well and measure maximum width... if you have the room, then you can do it, but you have to get a wheel that lines that width up using the right offset (probably on the high side, which is a +42 or +43). Even if it does clear, you may rub on the sharp corners as the suspension loads up.
Old 04-25-2005, 09:16 AM
supertack's Avatar
Yah, I have a lowered suspension as part of my sport package, & the rear would definatley cause rubbing. I toyed with the idea of wheel spacers for about 2 seconds, but with the lower suspension, the rears have to have to really be right on with the tire size.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-25-2005, 09:27 AM
