Wont Start/Stalls... HELP!!!!
So the other day my car, while idling for ~15 minutes, sputtered and died. It never usually would do that. I've also noticed in the last day or so, a slight stumbling at idle at stoplights or in traffic. Today I went out and my car just wouldn't start. Actually, it would start, then stall instatly. Start. Stall insantly... literally 100 starts (god bless my batetry) before it would hold. While starting even with some gas it would rev up for a half a second or so... then die.
On friday I got my car back from the shop, after an oil change and tracking down a hidden leak from the thermostat O ring. car runs fine when running...
Thoughts?
Old 03-15-2005, 09:58 AM
camaroman's Avatar
Not to ask a stupid question, as I'm sure you've already thought to check it, but are you sure that your fuel pump is working?
Mike
Old 03-29-2005, 09:49 PM
jase007's Avatar
You need to post what model of car... and what you have checked so people can help you ...
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 04-01-2005, 11:03 AM
scintaar's Avatar
Check the ICV ( Idle Control Valve), give it a bit of clean and see what happens. But be careful... they're delicate and non fixable!
... you don't need eyes to see, you need vision!
95 Mitsubishi FTO V6 MIVEC
88 944s
92 BMW 320i - E36
88 BMW 320i - E30
Old 04-06-2005, 08:16 AM
Scintaar,
What do you use to clean the ICV??? because having this problem as well.
Old 04-13-2005, 09:14 AM
scintaar's Avatar
Plain ol' carb and injection cleaner'll do.
Disconnect the ICV from the main intake hose, keep the engine running... if you can... and give it a couple of squirts.
88 944s
92 BMW 320i - E36
88 BMW 320i - E30
Old 04-13-2005, 01:31 PM
