problem solved,no spark
Hi,just to let you know my no spark problem now sorted,it was the fuel pump relay,replaced it and all is o.k.
thks. |
In case you have problems in the future you should understand that your problem was never 'no spark'. In your original thread I asked if you were sure it was no spark and I don't think you understood what I meant.
'No spark' is a very specific problem. Your problem should have been described more generally as 'wont turn over' or 'wont attempt to start.' By saying 'no spark' you eliminate our chance of helping you diagnose a fuel issue because 'no spark' is an ignition or electrical problem not a fuel delivery problem. Anyway, before you say 'no spark' you need to have determined that the plugs are indeed not sparking. I hope this helps and will help you post car problem questions in the future. Good to hear you got it fixed. |
| All times are GMT -8. The time now is 04:35 PM. |
