BMW Roundel fuel leak...PLEASE HELP!!!
i discovered a fuel leak on the undercarriage located on the drivers side approx. in the middle of the car. i believe it is the fuel hose. how do i replace this hose without taking it in to the dealer? also, what are the sizes of these hoses. i checked the tech article fuel pump replacement and i noticed that there are two hoses connected to the unit. what are the sizes of these hoses so i can order the right one from pelican. any replies to these questions will be greatly appreciated. thank you
Old 05-30-2005, 02:50 AM
Jeron's Avatar
Is it a damaged hose or a loose connection? If it's a standard rubber hose could you pull the hose, plug the lines and take the hose to find a suitable replacement?
With some pics and the model I could try to look up the part in my ETK. Last 7 of the VIN would help.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-31-2005, 09:23 AM
fredo328's Avatar
I just replaced my fuel filter and also had to replace the compression bands otherwise it probably would've leaked. Have you checked around the inline fuel filter to see if you leak is coming from there?
Old 05-31-2005, 07:32 PM
