DME for 1994 320i E36
My 320 let out a puff of smoke into the cabin then started running like it lost a cylinder. I brought into the dealer today and they said I blew a spark plug coil. No big deal, however it fried the circuit in my DME for this cylinder. Consequently I am looking for a DME PN Siemens 5WK9.003MS40.1, BMW pn 12-14-1-744-709 (uncoded), 12-14-1-744-959 (coded).
Has anyone had a similar problem. I find it hard to believe that I blew the brain out of my car simply because of a failed coil. Should I be looking at changing out the other coils? Ross Trilsbeck, Calgary Alberta 403-650-0759 rosstrilsbeck@shaw.ca |
I just had my DME apart for another reason. I did not pay much attention to the coil drivers, but if they are discrete transistors, you might be able to repair the DME.
Tim
1986 911 Cab 2008 Audi A6 |
the coil must have shorted out and sent thousands of volts into the DME
http://www.parengstrom.com/bmw.htm |
Tim
I agree... sounds like you lost a power transistor of some sort. It should be pretty easy to spot... most of them are rough-surface ceramic, and it's probably got carbon discharge on it (I had to change one out on a sputter coater a while back). It should be pretty easy to replace, but I hope you can figure out what the correct replacement is. I highly doubt BMW has a part for their power transistors. Most discrete parts are labeled, so I hope this one is too.
