Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
944_S_type's Avatar
Unhappy Power window motor???
Hi I finally just picked up my 1994 325is. It is like new, minus a couple problems..... This post is for the passenger window. It rolls down just fine. BUT, A couple times when rolling up, it stopped got kind of stuck, then rolled down, even though I was pressing up on the switch.
Any suggestions? I was thinking the regulator/Mechanical gear....
1994 BMW 325IS- my ride
1987 Porsche 944"S" -SOLD
2003 Honda CIVIC-the wifes ride
Old 07-15-2005, 02:15 PM
blkongry's Avatar
Yeah, it's the overload sensor tripping and causing the window to go back down. I'd start with pulling off the door panel, getting some good lithium grease and grease the regulator gearing, rollers, and track. See what happens with that.
Old 07-16-2005, 10:31 AM
944_S_type's Avatar
Very good, Thank you.
Old 07-19-2005, 11:00 AM
BMW Roundel
U need a new motor-->if its original regulator you might as well
replace it becuz you have to drill it out to replace motor
Old 07-20-2005, 03:15 PM
Author of "101 Projects"
Wayne 962's Avatar
Chances are it's the internal plastic bushings that ride along the regulator. Replace those, and it should work fine. I have a tech article coming soon on this, but here's a photo:
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997
Coming Soon:
SPEED READ: Porsche 911 (October 2018)
Old 07-22-2005, 10:04 PM
944_S_type's Avatar
Cool Thanks for the info. Is there 1 or 2 per door? Do you have a part number for these? Either Pelican/ or a BMW number.
Old 07-28-2005, 12:18 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
