-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   radio code (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/234481-radio-code.html)
larry309 08-04-2005 01:57 PM
radio code
'99 323is, I left the trunk open in the garage, dummy me, the battery went dead, what a surprise!!!! When I tried to enter radio code the radio says CODE WAIT, I have disconnected the battery for 5 minutes, left the key in the #1 position for one hour, pulled the radio fuses, nothing works. How do I get the CODE WAIT out so I can enter the correct radio code?
BMWCowboy 08-04-2005 06:52 PM
only way is to leave key on with radio saying code wait for one hour then enter code
Jeron 08-04-2005 08:42 PM
If you had a 99 323i that wouldn't have happened. LOL
So assuming you did leave it in #1 for and hour then I suppose BMWCowboy is saying you need to leave it in #2.
#0-off
#1-acc
#2-on
#3-starter
Wayne 962 08-05-2005 01:51 AM
Right - hook up a battery charger to the battery and then leave it with the accessory position on (radio says CODE WAIT). It should work then...
-Wayne
