While waiting for a tech/service manual does anyone have any quick checks for an inoperable automatic retractable soft top?
james39 ![]() |
Junior Member
well, did you pull the emergency motor disconnect?? It would be a small red tab under the rear driver seat. This would disconnect the BMW convertible motor.
After you check the fuses try this.
http://home.att.net/~ebaines/converti.htm It worked on my 94 cab
"The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does an oil change. It's a pity the ECU is so damn temperamental." 1980 911SC #99 track car |
CEO, Pelican Parts Inc.
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman Coming in 2012: • 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997 |
Also, if your trunk wiring / switch is not working properly, it won't let you open the roof...
-Wayne
Also, if the windows are up and one of them is broken / not working, it won't work either.
-Wayne
Wayne,
You proable hit the target as my driver window moter is broken. I am waiting for delivery on a new motor. Thanks for the data. James39 |
-Wayne
