supertack's Avatar
Central Locking/One Touch Windows
Two separate issues I'd like to take care of. Logistics: '97 328is.
1. The central locking system is not working on the driver’s side door. If all the doors are locked, & I unlock the driver’s side door, the passenger door & trunk will open with central lock assist, but the driver’s door is unlocked with manual force. If all the doors are locked & I unlock the trunk, the passenger door & trunk will unlock with central lock assist, but the driver’s door will not unlock. The same is true for locking.
2. The one touch window feature is FU'd on both doors. The driver’s door will not work at all. & the passenger door will go up half way, then quit. Some times the passenger door will go up all the way, but if I attempt to start closing the driver’s door or sunroof manually, the passenger door window will stop.
I know BLKONGRY had some issue with his one touch motors, & of what I remember it wasn't a pretty fix. Any impute would be great.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 10-06-2005, 07:44 AM
check the drivers side actuator ---
1993 325IS Turbo
T3/T04e
M3 Cams
Old 10-06-2005, 08:16 AM
jtfreels's Avatar
Well, dont want to hijack this but I have similar problem. In my 99 328is, the passenger window wont go down. If I press the button either up or down I can hear a faint click from the passenger door.
Now the big question, how do I get the door panel off? A quick check showed no visible srews etc. An that door air bag gives me
a scare. Any tech articles on getting the panel off?
Jay
2002 Boxster Speed Yellow
Old 10-06-2005, 08:33 AM
supertack's Avatar
Geno, care to ellaborate on that little nugget of information? Explain that to me like I'm in 6 years old.
97 328is
Old 10-06-2005, 09:00 AM
LOL, antonio! pull your door panel off and check the electrical actuator that pushes up/down your locking mechanism
cant miss it
1993 325IS Turbo
T3/T04e
M3 Cams
Old 10-06-2005, 09:34 AM
Send a message via AIM to percious
Judging by your comments, you probably need a new comfort relay, it is located under the driver side panel, its blue.
-percious
Old 10-12-2005, 02:11 PM
DIY for the comfort relay here http://members.roadfly.com/petah/e36comfortrelay.htm
http://www.parengstrom.com/bmw.htm
Old 10-13-2005, 03:19 AM
supertack's Avatar
Folks, the comfort relay is if the power windows won't work at all. My windows go up & down, they just don't work on 'one touch mode'. I thought that was pretty clear from the initial post.
97 328is
Old 10-13-2005, 10:46 AM
LOL
Wasup with your drivers side lock tho? check out the actuator?
1993 325IS Turbo
T3/T04e
M3 Cams
Old 10-13-2005, 10:51 AM
then, if you have disconnected the battery at any time you have to re-initiate the one-touch function, lower your window(s) then up and after they gone up, keep the button depressed for 10seconds, that will teach them;-)
Old 10-13-2005, 11:17 AM
