Adjusting ignition timing.
I have an early production 92 E36 325is. I'd like to play around with ignition timing. I am used to cars having a cam angle sensor that can be turned to adjust the timing, but I can't find such a thing on the 325. Are there ways to adjust timing on these cars?
Thanks, -J |
As far as I'm aware, there isn't a way to do this.... it's all controlled by the ECU.
You might just go for a remap... or change the cams for performance parts..
... you don't need eyes to see, you need vision! 95 Mitsubishi FTO V6 MIVEC 88 944s 92 BMW 320i - E36 88 BMW 320i - E30 |
is there a way to adjust mapping yourself with special software?
Pre, what is it, '98? or so?, all the ECU programing was hard coded onto the chip, like a CD-ROM... no remapping the ECU unless you get a new chip in there.
I have a 95 E36 325Is and was told the same thing blkongry said.
I was told to get a new chip.. |
