-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   engine revs up/down when warmed up (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/240162-engine-revs-up-down-when-warmed-up.html)
Brendan Daly 09-09-2005 11:50 AM
Once warmed up '87 325E engine goes into continuous cycles of engine revs going up then down in fairly rapid succession. Repeats about every 1 to 2 seconds.
Any ideas about the problem ?
Brendan
Bear 09-10-2005 07:07 PM
Idle Issue
Sounds like the Idle Control Valve (ICV). I would remove it and clean it out (internally) with some throttle body spray cleaner.
Brendan Daly 09-13-2005 06:31 PM
Bear,
I will give it a try this weekend. Thanks for advice.
Brendan
Brendan Daly 12-30-2005 03:05 PM
Today, I finally got around to removing the ICV and cleaning it internally. I actually used carborettor cleaner. When I replaced it, it did not immediately fix the problem. however after I drove the car for about half an hour I noticed that the car was revving at a lower RPM. I think the carb cleaner I used was actually clogging the ICV somehow and it evaporated when the engine got warm, thus clearing the opening in the ICV. (My theory!) I should have bought some throttle spray!
The car now revs at 1000 RMP when stopped in park and 500 rpm when stopped in drive. Is this correct ? I tried to adjust the ICV but the screw cannot be adjusted any lower.
