rear wheel bearing replacement
has anyone replaced a rear wheel bearing on an e36? if so let me know. I don't have much info. on it and the tech article on here is for an e30. are the bearings pressed in? do they come already pressed in a new hub or do I need to get them pressed in myself? pelican lists both a hub and the bearings, do I need both of these ? I'm really clueless on this one. any help would be great. thanks. ----- mike
Old 10-26-2005, 08:46 PM
I'm with Bill
Rick V's Avatar
it's pressed in you don't need to replace the hub just the bearing. The instructions are the same as for an E30. Fairly simple job.
Good luck
Old 10-27-2005, 01:32 AM
thanks rick. I'll use the e30 article. any idea on how I get them pressed in ? also. are the front the same ? thanks again ------ mike
Old 10-27-2005, 09:23 AM
