tachometer/fuel economy gauge
I have an 88 325i convertible with an instrument cluster problem.
I cannot get the tach and fuel economy gauge to work.
I understand that the main culpret when this happens is the batteries in the service indicator board going bad.
I have removed the instrument cluster and service indicator board and even gone so far as to remove and re-solder new lithium batteries into the board. But to no avail. I even replaced the board whith a known good one and no tach.
I have checked voltage and ground at the three plugs on the back of the instumrnt cluster per the bently manual and it checks out. Also I am getting fuel economy signal to the on board computer because it is calculating average mpg and range.
I have also replaced the tach and fuel economy gauge with a known good one and it doesn't work.
Any one with any clues?
I've invested too much to give up at this point.
I might have to install another car on the gauge!
Old 10-10-2005, 11:34 PM
I put a new motherboard in. I had a strange similar problem, with the tach not working. After changing many of the components in the cluster (tach, fuel, speedo, SI board, and motherboard, I somehow came up with a combination that worked.
Old 10-11-2005, 06:29 AM
Did your fuel economy gauge work before and afterwards?
I assume by motherboard you are refering to the motherboard the tach and speedo plug into. Unfortunatly I did. sort of.
I put an instrument cluster out of my 85 325e that works in it, but not in my 88. I assumed it was because the 88 is motronic.1 , and the 85 is the older version Motronic DME, even though they look identical.
But you my be onto something that could work for me also.
I think I will try swapping components and boards around to see what happens. I already have the steering wheel and the trim off.
Thanks, Panzer.
I'll let you know.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 10-12-2005, 05:39 PM
I think the FEG went out too, perhaps the whole right side of the cluster as I believe I was chasing a faulty water temp gauge. I know the 'e' cluster won't work correctly because the tachs are different. I 've done this to hilarious effect. The 'i' motor will rev way past the redline with the 'e' tach. My parents own an auto parts store so I was able to frankenstein a few different clusters and see what works. You may be on to something with the DME vs. 1 thing. Just be EXTREMELY careful with those plastic tabs on the top. BTW, I probably changed the SI board in the process.
Old 10-13-2005, 05:51 AM
flatlander's Avatar
My 88 iX had this same problem and I did all of the things that you have mentioned while trying to fix it. My speedo had also stopped working so it was a slight adrenaline rush while in the proximity of police. Anyway I got the speedo working but the tach and feg still didn't work. shortly after all the work I went out to a dead battery...I had left my Sirius receiver turned on for a few days. I couldn't get to the battery since my key won't open the trunk so I had to charge from the starter connection. Don't ask me why but since that day the tach has worked fine. The feg even worked for about a week and then died again. Two months later and the tach and speedo are still working. My assumption is that there is a connection at or near the starter that was loose that I bumped while jumping the car.
Old 11-05-2005, 10:04 PM
I fixed it. It was the SI board. The one out of my 85 won't work in the 88.
Go figure.
I purchased one on e-bay for 35 bucks + shipping. All is good in 88 e30 cabroland.
I am putting it for sale in the mullet wrappers (Auto trader and the like, for those of you who don't speak Florida Cracker).
Old 11-06-2005, 09:29 PM
