BMW Roundel Coolant Expansion Tank Replacement
hey everyone,
(1987 325i Convertible--prod. date: 06/87)
can anyone help me by giving instructions (preferably with pictures) on how to remove the coolant expansion tank, radiator, and thermostat. i need to replace these items in my vert because they are worn. the expansion tank cracked due to the plastic turning brittle. the radiator has needed a change for awhile but i didn't get around to doing it. and the the car has been running on the HOT side so i need to replace the thermostat. i had the timing belt and water replacement change about two years ago (at approx 70,000 miles). the car has approx 120,000 miles on it. any replies and help would be greatly appreciated.
aloha from the 808 state
P.S. This question goes out to Wayne or anyone at Pelican that can help. Can you tell me the item numbers for what i need as far as replacement hoses for the radiator and coolant expansion tank, and thermostat. thanks
Old 11-08-2005, 11:22 AM
