Question 3 beeps
The last few weeks I noticed that my BMW 321i Cabrio makes three short beeps once in a while, always during normal driving. The beeps sound like the ice alert, but that's only one and if I recall correctly it sounds a bit different.
Anybody any idea what the car is trying to tell me?
Old 11-17-2005, 03:48 AM
supertack's Avatar
Your 'memo' alert is on. Look on your obc, & find the memo button. This can be set to give three short beeps at any pre-set time you like. If you look at the display where your clock is, you should see a little icon showing that the memo is on. If you turn the memo off, this icon will go away.
Your right about the ice/freeze alert. That is a single chime as opposed to the three short beeps of the memo function.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 11-17-2005, 04:02 AM
Right, that's it. Thanks for clearing that up!
Old 11-17-2005, 06:36 AM
