-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Dfference between an m3 front sway bar and a 318ic front sway bar (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/257356-dfference-between-m3-front-sway-bar-318ic-front-sway-bar.html)
lozer 12-21-2005 08:08 PM
i have both, the m3 sway bar is smaller in diameter then the convertable. which one is going to be stiffer?
Jeron 12-22-2005 07:48 AM
Are they the same size and shape?
Dave at Pelican Parts 12-22-2005 10:54 AM
If all other things are equal (length, shape, mounting points on the suspension), the thicker bar will be stiffer and the thinner bar will be less stiff.
--DD
