-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   start up problems (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/258165-start-up-problems.html)
codger318 12-28-2005 11:46 AM
start up problems
At start-up my '92 318is will intermittently "backfire" (usually accompanied by an electronic "grinding" noise). This "backfire" is not in the exhaust, but intake system. This event will usually blow the j-shaped moulded hose off the Idle Control Valve. Most recently it blew up the rubber air duct between the air filter and throttle. I have changed the O2 Sensor (and the blown duct), but the problem has reoccurred.
Any ideas?
parolof 12-28-2005 12:16 PM
what an electronic "grinding" noise"???:-))
codger318 12-28-2005 12:22 PM
sounds like an electric motor (but is not the starter, or any other source I can think of)
LiquidBMW76 12-28-2005 04:17 PM
Sounds as if you are getting spark before the intake valves have a chance to close
