325is subframe
Just had my subframe break at the differential. Has anyone had this replaced or repaired? Is it worth it. The car is a 92 with 150,000 miles. Runs great otherwise.
Old 01-06-2006, 12:28 PM
You broke the diff bolt / mount or your subframe floor is ripping out? I had the Turner reinforcement plates welded in on my car-
1993 325IS Turbo
T3/T04e
M3 Cams
Old 01-06-2006, 12:45 PM
The subframe is ripping out. The Turner kits are preventative, but not a fix at this point. Just wondering if anyone has had this problem and whether they had to replace the subframe.
Old 01-06-2006, 12:57 PM
yup, mine started cracking and had the floor welded and then the Turner plates welded in- fun stuff!!
1993 325IS Turbo
T3/T04e
M3 Cams
Old 01-06-2006, 01:00 PM
The subframe is ripping out. The Turner kits are preventative but not a fix at this point. Just wondered if anyone has replaced the subframe or was able to fix it without a complete replacement.
Old 01-06-2006, 01:02 PM
I had mine done this fall, and i had one of them completely torn off, i had to weld turners plates,three of them,and fourth one ,i had to make one up,ofcourse with the plate too. I'll post some pics later , not that it will help alot ,it wasn't fun for me.
y.a
Old 01-07-2006, 02:37 PM
