question probably not asked
92 325i . I have a blk exterior with like a grayish bottom. when i put armor all on it the grayish looks great. when it wears off it looks like crap. is there a product i can use to keep it looking great? any suggestions would be appreciated
If it is plastic, clean and scrub it with soapy water and a nylon kitchen brush to get it clean.
Then try Mothers Back to Black. It will look still eventually turn back to gray but repeated application of Back to Black should help. |
I have the gray fade too. There is some paint that you can apply on the gray at home. check out the unofficalbmw forum and scroll down to paint code for gray skirting.
could you please link me to that page. Thanks
where can i get mothers back to black at?
Mothers is sold a Pepboys. It is for plastic. I dont know if your gray skirting is plastic or painted, I'm just guessing.
Also, not to recommend other sites on Pelican because I love everything about it :) But Bavarian Autosport(bavarianauto.com) has a kit just for this purpose and its DIY friendly...I think it was costly but worth looking into.
That looks intriguing let us know if it works. The one I saw was only $12.
It looks like Pelican sells some stuff too. I know the 88 911 has some huge plastic expanses, like the whale tail for instance, I wonder what the old men use on those. <kidding> |
I was wrong on the page... ************
I knew what you meant. :-)
I should have mentioned it but I just automatically typed in bavauto. |
Try the following link it adds another avenue to pursue.
Color matching the grey side skirts |
(Click for a larger image)
Restore faded rocker panels. No masking, no spraying! This refinishing kit uses a brush-on, water-based polymer. Kit includes cleaner, high-pigment coating, foam brushes and how-to video. Part Number Description Price 07500100001 Rocker Panel Treatment $59.95 Heres the description, they dont have a tag but if you enter your make and key search rocker panel this is what you get....very nice stock change if you have the stock molded rocker panel as I do on my older e36 3-series. |
Nice recommendation Liquid...especially if you want the stock color back.
| All times are GMT -8. The time now is 04:53 AM. |
