e30 OBD pin-out
I was wondering if you could provide me with the pin-out of the OBD 20-conductor receptacle for my 1989 325iX. I especially need the correct wiring color to pin lay-out . I am unwiring a dealer installed modificaton and the technition pulled some wires off of the OBD receptacle and taped them up. I want to put them back in their proper location.
Old 01-18-2006, 01:26 PM
James,
The following is what I was able to dig up on the 20-pin OBD:
Pin Wire Size Wire Color Circuit and Component Connected
1 1 BK Ignition Coil, Motronic Control Unit
6 0.5 WT/BK SRS Connector (Not Used)
7 0.5 WT/GN Service Interval Indicator, Service
Interval Processor(Reset).
11 2.5 BK/YL Starter, Start Signal(50)
12 0.75 BU Charge, Alternator(D+)
14 2.5 RD Battery
15 0.5 WT/YL Motronic Control Unit(RXD)
16 1.5 GN/WT Oxygen Sensor
18 0.5 GN/BU Motronic Control Unit(Programming Voltage)
19 1.5BR BR Ground Distribution(G103)
20 0.5 WT/VI Motronic Control Unit(TXD)
Old 01-20-2006, 01:52 PM
