Unhappy Lost Something
I just replaced the wiper transmission on my daughters 91 E30 318i, a midblowing experiance i might add. Anyway, after putting everything back together i not longer have a tach, water temp. or econ gauge signal, input or whatever. Everything else on the dash seems to be working except these three, and the car runs fine. I have looked for broken wires and haven't found anything. Any help would be greatly appreciated.
Old 01-24-2006, 03:45 AM
Send a message via AIM to wludavid
It seems obvious, but have you checked your fuses? I occasionally have a few gauges stop working on me it's due to a blown fuse.
However, the cause of the blown fuse is a little weirder. IIRC (and I could be totally off on this) the backup lights and some of the gauges run off the same fuse. There is a tendancy for the wires coming off the backup switch on the transmission to work themselves loose and get a little chewed up under the car. They can rub against the chassis, creating a short circuit and a blown fuse. If you have the bentley (or the owner's manual, I suppose), study the fuse charts and take a look what else is on the same fuse as the gauges you mention. Start hunting down what else doesn't work from there and maybe you can find the problem.
1987 325 eta
Old 01-24-2006, 08:32 AM
I have checked all the fuses and they're all ok. I was going to check the temp and engine speed sensors with info from a mitchells manual but i can't seem to find what the parameter for the speed sensor is.
Old 01-26-2006, 12:28 PM
