Exclamation Idle problems on project car
I am in the middle of converting my E36 M3 into a racecar. The interior is completely stripped out, wiring harnesses are exposed. I went to start the car and it is now running rough and dies when I try to reverse w/ clutch still engaged. Have I created a short? Thanks for your thoughts.
Old 12-30-2005, 08:32 PM
Eli at Pelican Parts's Avatar
Looks like a quick trip to shop would be better than anyone over the net. Any suggestion without actually seeing the car would be a total shot in the dark..... When you said "completely stripped" you didn't really mean completely right? ECU........
-Eli
Old 01-12-2006, 08:23 AM
lots of things could be causing this! Fueling problem, damaged hoses ICV, MAF, etc etc
http://www.modifiedm3.co.uk
Supercharged, PSS9 Suspension, AP Racing Brakes,Dual Custom Zorst, 19's,lowered,Angel eyes,HID,Crystal fogs,Lumma CLR bodykit. UUC Short Shift, etc etc
Old 01-29-2006, 02:40 AM
