Question Rear Wheel Alignment - E30
Can anyone give some direction? I am new at rear wheel alignment. '87 E30/325 is wearing on the rear wheels and the rear wheels are kind of pidgeon toed (front of tire points outward) and wearing the inside edge of the tire.
Is there an easy (understanding time is required) to adjust it? I have help from a guy that does all the work on his own cars, but a rear alignment is not part of his repetoire of knowledge.
Please help.
Thanks,
Bryan
Old 02-07-2006, 06:26 PM
Mr.
The rear end of E30's is not allignable. About the most you can do is replace the trailing arm bushings. If that does not do it for you, then you would be looking at replacing the trailing arms - that should be quite expensive though.
Old 02-08-2006, 08:22 AM
