-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   how can i find e36 guides and display errors? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/265314-how-can-i-find-e36-guides-display-errors.html)
hotshotd 02-08-2006 05:22 AM
how can i get e36 1997 3.28i bmw user guide? can anybody help me?
Thank
Jeron 02-08-2006 07:09 AM
Do you mean owners manual? You'll probably have to buy from the dealer.
The best repair manual is Bently but Chilton and Haynes each make one too. The Bently is a subsitute for the Owners Manual in several areas but all.
Wayne, Pelican CEO, has a repair book comming out in March that is similar to the Tech Info Center on this website.
hotshotd 02-08-2006 07:53 AM
thank you very much my bmw screen appeared one error message. i mean one sign. maybe break do you understand? how can isend this sign to you? do you have msn ?
my msn is: ercan_eris@hotmail.com
Sincerely
Jeron 02-08-2006 08:10 AM
The brake sign is a circle with 2 curved bars. Like this >>> (O)
I usually means you need new brake pads. There is a sensor on the LF and RR brake pad that wears through when the pad gets low.
If this is true then you need to replace the pads and the sensor. The light will go out by itself soon after the repair is done.
hotshotd 02-08-2006 08:25 AM
thank you. you are true. i will go service.. i was thinking the same but i wasnt sure. now i am sure after you.
Hey thank you very much.
Sending greetings from Kazakhstan
