Cam alignement marks
I have a quick question? I need to check to the alignement of both of my cams, where are the marks to make sure their at tdc?And how do I set them if there not a tdc.I had some work done but, they tried to screw me, so took car home the way it was, i'm sure my cams are off.(i hope no bent vavles too!!)
I'm with Bill
what kind of car and what engine? I will assume you have some form of newer 3 series car. There are no alignment marks. there is a set of tools used to set the crank and cams to the proper positions. One is a pin that goes through a hole above the starter and the other is a set of locking blocks that hold the cams down.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
the car is an 92' non-vanos, the car sounds like the timing is off. If the timing was would it effect the compression test
I'm with Bill
Yes it can. I retarded my exhaust cam 4deg. and advanced my intake cam 2deg and the compression went up 20psi. Idle is a little rough but it spools quickly and works well with the light flywheel.
Ok, I bought this from my friend, the headgasket is post to been replaced but the compression is high on the #1 slight goes down 2-6. and the when i try to turn it over sounds like the timing is off. its got spark and gas. I looks as if the cams are off.
