hi folks
hope someone can help me??!! i just bought a j plate e36 318i auto,it had a falt when i got it, it would start from cold and drive fine for about half a mile,then it would miss and them back fire through the inlet,so i thought it must be the cat(blockage)so i got a new one!.......yes you guessd it,no change. got a mate of mine to plug in the snap on box,and everything seemed to be pointing to the air flow meter,so i stuck another one on,started the car and took it for a run,it was driving great!........for about half an hour! what happens now is it starts no problem first time everytime,and drives fine for a few miles then it starts missing but when i give it full throttle its fine,if i pull over stop the engine then start it again it drives fine for another couple of miles then back to square one again!!!!???? please help
no german?..no good!!! |
sound like something is malfunctioning when the it gets warm/hot, don't know much about the 318i's, have you got one or four ignition coils? Had a similar problem on an old Ford, the coil shorted out when it got hot
http://www.parengstrom.com/bmw.htm |
problem
Sounds like the temp sensor for the dme.
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
Re: problem
where is this sensor? how much are they?
