-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   failed dme HELP!!!! (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/282004-failed-dme-help.html)
orangebmr 05-10-2006 12:06 PM
failed dme HELP!!!!
First off the dme got flooded so I replaced it then I replaced the
fuel pump relay then the crankshaft sensor and the camshaft
sensor. then when I tried to start the car it would not start it
would just turn over then it started grinding like it was the starter
or something??
Jeron 05-10-2006 12:20 PM
Your description isn't very detailed but if the starter is making a grinding noise it could be the solenoid which means you need a new starter. I don't think they are owner serviceable.
However, the first thing I would check is the battery.
orangebmr 05-10-2006 10:11 PM
Its a 94 318is and I think your right but what I cant understand is why
it would not start when it was turning over could it be the dme relay??
thanks
Jeron 05-11-2006 08:59 AM
I've had a bad battery turn the engine but not start on more than one occasion.
As far as the turning over for a bit then a grinding noise I don't know but it sounds like the starter. I don't see how a DME relay could cause a grinding noise.
orangebmr 05-14-2006 01:55 PM
The grinding has stopped but it still wont start its not getting fire
orangebmr 05-14-2006 01:58 PM
things I have replaced - dme, dme relay, fuel pump relay, camshaft sensor, crankshaft sensor, spark plugs and still no fire
could it be a problem with the other dme???
