manual tranny oil change
Hey guys,
I want to change the oil in the gearbox, but am having a bit of trouble locating the fill/check plug. Is it on the passenger or driver side? My tranny has no label on it (that I can see, maybe it's been ripped off after 19 years). The car is an 87 325, 2.7L. My guess is a Getrag 260 tranny.
Also, any advice on the type of oil to refill with?
Any help is appreciated. Thanks!
Old 06-14-2006, 04:55 PM
jase007's Avatar
Don't remember exactly which side the fill plug is but ... you might need some leverage to get it off [I believe they are tapered].
I use redlines products [MTL - manual transmission lube] and gear oil [front and rear differential] transfer case too.
Make sure you can remove ALL fill plugs before taking the drain plugs out. Will save yourself a headache of draining fluid only to find you can't remove fill plug to fill.
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 06-16-2006, 11:49 AM
redline,...redline,...redline!! solves all problems
Old 06-17-2006, 06:47 PM
It is on the drivers side about 3/4 up the height of the transmission. I drained and filled mine using jack stands but a lift would make it easier. You will need a pump to get the fluid into the trans. I used a hand a finger pump I got from Pep Boys.
Bill
Old 06-18-2006, 10:46 AM
