Question HELP! with Transmission Removal...
I am replacing the clutch on my '98 318i. I have been following the Pelican Parts tech article to the letter. Everything has gone well until now; I am at the point of separating the transmission from the engine. I can get them about 3/4" apart, but no more. The trans seems to be hung up somehow on the starter. I am sure I have the two starter bolts out, yet I can't get it any further apart. Shouldn't the starter be hanging free at this point? Does anyone have any experience/suggestions???
Old 10-06-2006, 06:02 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, it can't be held up on the starter, as the starter, flywheel, and clutch are attached to the engine, not the transmission.
As I write in the 101 Projects Book, there is a metal "seal" that is connected to both the transmission and the engine. Some bolts attach it to the tranny, some to the engine. You probably missed a bolt that is facing the opposite direction?
-Wayne
Old 10-07-2006, 01:36 AM
Okay; I will check for that possibility. If there is a bolt facing the opposite direction at the top of the engine, it's going to be a bear to get at it...
Old 10-07-2006, 05:13 AM
I figured out what the problem was: The dowel pin that helps to align the starter with the transmisssion was corroded. A squirt of liquid penetrant and a long screwdriver between the starter and the transmission took care of the problem.
Old 10-07-2006, 09:57 PM
