-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   oxygen sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/293827-oxygen-sensor.html)
DFL 07-17-2006 07:37 AM
oxygen sensor
The Check Engine light is on; did the the gas pedal trick and got a 1221 error code for bad oxygen sensor. Before I order any parts; just wanted to make sure that there is only one sensor and ask if there are any tricks to replacing it. Any advice would be appreciated. I plan on ordering the removal tool to make things easier.
Jeron 07-18-2006 08:12 AM
Depending on your model you could have up to 4 O2 sensors. Get penetrating oil and and the sensor tool.
DFL 07-18-2006 10:50 AM
It is a '95 325i with 89,000 miles. Will Bentley tell me how many? Is there any way to narrow down which one it is, if there are this many?
Jeron 07-18-2006 10:55 AM
According to Bentley you have one, on the Y right in front of the cats.
DFL 07-18-2006 03:56 PM
Thanks! Only having to replace one is definitely cheaper and easier.
