A/C 7.5amp fuse keeps blowing
I have continually replace fuse number 39 (7.5amp) and it keeps blowing out. I have ordered an A/C pressure switch coming tomorrow. Any ideas?
Does it blow immediately, or over time? Immediate indicates a short circuit, over time means that the motor is probably worn and drawing more current than it should...
-Wayne |
Found the problem. Exposed wire from Compressor causing it to ground itself blowing the fuse immediately
Thanks |
| All times are GMT -8. The time now is 07:07 PM. |
