Can a 95 318is be flat towed?
Inquiring if a 95 318is, 5 speed can be flat towed behind the RV over extended distances . Not interested in a tow dolly or car carrier.
Old 09-15-2010, 04:50 AM
I can't think one reason not to tow a 5 speed. I have pulled mine, only because it would not go on its own.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 09-17-2010, 10:58 AM
I want to pull it behind our RV since I can't tow my 335 or the wife's Z4.
Old 09-20-2010, 03:55 AM
As far as I know, if it is a five speed, manual transmission, two wheel drive, ( the only ones I have ever had for 35 years) put it in neutral, release the brake.
You should be able to push it by yourself on flat ground. I do it all the time.
They roll good. Never had an RV, only boats, since they don't float they stay home.
Old 09-20-2010, 08:05 PM
poorsche930's Avatar
No, it is recommend to remove the driveshaft & your good to go. COMMOM flat tow info
Old 10-06-2010, 02:16 PM
SharkHead
JhwShark's Avatar
+1...the differential only likes getting load from the engine...
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 10-06-2010, 02:38 PM
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-06-2010, 05:12 PM
Wheels pushing diffy -v- engine pushing diffy. One comes through the driveshaft, the other comes through the half shaft...pushes on opposite sides of the gear teeth...
Old 10-06-2010, 08:07 PM
What difference does that make?
Diffs can handle engine load on drive side and brake or coast load on coast side.
Old 10-10-2010, 12:55 PM
Any more thoughts on this guys, I didn't think it made any difference on an LSD diff or open diff? We put our race car on a two wheel dolly and pull it with no obvious problems?
Old 10-12-2010, 10:59 AM
If it made a difference, you could not push in the clutch and coast. I don't know alot, but I do have 30 plus years of experience with BMW's, and all with manual transmissions.
Based on what I know to be true, you can pull the car to the moon.
You may need to replace the tires on the way back.
It is a BMW, not a VW, A 3 series BMW's running gear is as basic as an AMC Rambler with CV joints and disc brakes.
Maybe not as tough as the Rambler, no doubt not worth as much as the rambler today.
I appologise for my prior reply, I was being coy, and obtuse, I have pulled them behind an RV, not to the moon, only half way.
Pull the thing 10,000 miles, it is a German Ford Pinto.
Then drive it to work on Monday. It won't know it went anywhere, but work.
Old 10-15-2010, 09:58 PM
