a few questions
hi, just got a p reg 96 320 great car, could anybody help me with some questions about the car.
1. the last owners said that BMW told them that this engine has no timing belt to change is this correct.
2. i can just make out the mileage, i have read that the bulb needs changing, where do you get these from and how much and is there a link showing step by step what to do.
3. the fan 3 and 4 work the same speed, 1 and 2 are fine is this a resistor problem? how much do they cost and is there a step by step guild.
thank you for your help
Old 09-04-2006, 05:24 PM
He is correct it is a chain not belt, the light bulbs you can get from pelican parts and here is a link on how to pull the instrument cluster out http://logun.org/gauges.htm , and yes it is probably your blower motor resistor which can also be found at pelican and here is how to replace it http://www.pelicanparts.com/bmw/techarticles/E36-blower_resistor/E36-blower_resistor.htm I hope this helps you
1993 318i manual
Old 09-04-2006, 06:47 PM
Thumbs up thanks mate
thanks for the quick reply going to sort it, this a great site
Old 09-05-2006, 12:58 AM
supertack's Avatar
I've got a tech article on the bulb replacement coming this week, but this is also detailed in Project 90 of the 101 Book...
Shameless plug no. 46 & counting.....
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 09-06-2006, 04:46 AM
