BMW Roundel A/C Problem...ANY Suggestions??
1999 BMW 323is E36: My A/c has always worked fine. It suddenly just cut out..no A/C and no lit-up display. After driving a bit it came back on, then off, then on, and so on and so forth. It would stay on after driving a while but every time i started the car back up it would take a while for the A/C to turn back on. I took apart the dash near the A/C and CD deck. (no abnormalities) i checked fuses, none are out. is there a relay that could have something to do with this?? PLEASE Help. Thanks!
P.S. the harness with the light blue plastic was pulled out by me for trouble shooting, it was normally plugged in. (In the Picture)
BMW lover, forever! David
Old 07-30-2009, 08:01 PM
This might help.
http://frontiernet.net/~Papi/Clim_Ctrl.html
Old 07-30-2009, 10:33 PM
thank you! these are the pictures i needed! i didnt want to jump into this project before i knew exactly what to pluck out and replace. thanks again!
Old 08-22-2009, 05:00 PM
