-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   ticking noise from engine (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/304027-ticking-noise-engine.html)
nimos 09-12-2006 03:27 PM
hi, i have a 320 v6 engine 1996 i have giving it a full service, the engine was very quite when ticking over but after i changed the spark plugs there is a ticking noise, have i done something wrong? or is the tappets thanks for you help
supertack 09-12-2006 03:47 PM
Gotta be the valves hitting something. Timing chain issues, I dunno. I've heard about the older 6ers having this problem a lot.
LiquidBMW76 09-12-2006 06:12 PM
Alot of the times it is the timing chain tensioner when you start getting a ticking noise.
Wayne 962 09-12-2006 08:11 PM
Right, you can try changing the chain tensioners, but I think he's describing a sticky lifter. When I had this problem, I changed oil to a thinner viscosity, ran the car a few hundred miles, and then changed back to a thicker oil, and it went away. Apparently flushing the oil out with different thin oils can help clear passages and bring lifters back to life. There's some more info on this too in the head gasket Project of the 101 book...
-Wayne
Jeron 09-13-2006 06:43 AM
Did you change engine oil grades during your maintenance? Is the noise when hot, cold or both?
Ticking noises are common questions and not always a problem. The chain tensioner is a good part to consider if it sounds like chain rattle. It could also be that you aren't used to hearing your engine running with the hood up.
nimos 09-14-2006 01:39 AM
thanks for that, will change the oil, what oil do you recommend, i got some synthitic 10/40
Jeron 09-14-2006 06:54 AM
In the summer, I use 10w40 in my E36 M3 in the winter I use 5w-30. I use Royal Purple. I would choose in this order: Redline, Amsoil, Castrol, Royal Purple, Mobil1. Mobil1 is at the bottom because I, and others have had consumption issues.
On another forum today, a ticking sound was diagnosed as a bad belt, a missing chunk of rib actually. It's worth a look
Wayne 962 09-15-2006 12:58 AM
I like Mobil 1, but it is a very thin oil, and can sometimes cause leaks on older cars, in particular air-cooled Porsches. The rule of thumb I typically have is if a car has been run with synthetic, then stick with it. If not, then don't. Keep whatever the car's seals are used to...
-Wayne
Chilly 09-20-2006 09:39 AM
Did you lean on the plastic fan shroud when doing the maintenance? Listen to see if the sound comes from near the radiator.
Chilly
Wayne 962 09-20-2006 11:13 AM
Chilly
Good thought - it may also be the radiator not mounted properly (there was another thread on this a while back), where the engine fan hits the shroud...
-Wayne
brka 09-23-2006 04:00 PM
Re: ticking noise from engine
This ticking noise could be caused by a loose spark plug. Compression escaping trough the spark plug socket can sound just as you described.
nimos 09-23-2006 04:16 PM
thanks for your feedback, i changed the oil and the ticking has gone, cheers
Jeron 09-23-2006 05:28 PM
Re: Re: ticking noise from engine
Funny coincidence, I've had a knock for the last few weeks and finally got around to looking at it yesterday. It was exhaust side and sounded like a cracked header or header gasket but I finally isolated the noise to the #4 sparkplug which was loose.
Wayne 962 09-26-2006 05:54 PM
Re: Re: Re: ticking noise from engine
Also, plugs can have their insulation fail, which can cause similar problems / noises...
-Wayne
