Send a message via AIM to Luke1212
Angry engine starting
I have a 1987 325e that I got with a bad engine. I have replaced the engine with new timing belt. The engine is a 2.5 and has low mileage. Now for the problem, The car turns over fine and will start for maybe 10 seconds than quit. It will not start after that
again until the next day. I replaced plugs, wires, cap, rotor and coil without any luck. I checked today and had fire at coil but not at plugs.
Anybody have an ideals, thanks
1969 T being rebuilt someday
1971 T who knows about this one but working
Old 10-12-2006, 11:21 PM
Author of "101 Projects"
Wayne 962's Avatar
Check the timing belt to make sure that you have set the timing correctly. Use this article as a guide:
http://www.pelicanparts.com/bmw/techarticles/101-Projects-20-E30-Timing-Belt/101-Projects-20-E30-Timing-Belt.htm
If you're not getting spark at the plug, then it sounds like there's a timing problem...
-Wayne
Old 10-13-2006, 03:05 AM
Are you using the wiring harness and DME from the 325 i motor or the one from the 2.7l e motor?
Keith
87 325i
96 328is
85 318
Old 10-13-2006, 07:27 AM
Wayne and Keith,
Thank you for the information and help. Sorry I did Not get back sooner.
Keith, I switched everything over and it all worked before. Wayne thanks and the article was great, believe that is where the problem is.
Again many thanks,
Old 10-20-2006, 09:09 AM
Also check your fuel filter if it is partially blocked it wil starve the motor but as fuel slowly seeps through would allow you to start it again at a later time.
1993 318i manual
Old 10-20-2006, 05:33 PM
