Author of "101 Projects"
Wayne 962's Avatar
E36 Owners - Check your trunk wiring!
About 50% of the cars I look at seem to have this trunk wiring harness problem, which can cause door lock problems, gauge cluster problems, and general electrical gremlins.
Pull back the plastic on the trunk harness (easy), and see if you see this:
-Wayne
Old 10-06-2006, 01:45 AM
supertack's Avatar
Can you expand? What are we seeing, & what should we do if we see this?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 10-06-2006, 05:29 AM
