-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Odometer gears (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/309569-odometer-gears.html)
gejettest 10-13-2006 07:01 PM
Odometer gears
Hi again,
Different subject, my odometer quit sometime ago, took it apart, found the gears stripped out (nylon). Went to junk yard, got some more gears, but being that they are all getting up there in their years, they all seem to disintigrate. Is there a source? I tried the parts (Pelican) but nothing showed up.
Thanks,
Henry
Jeron 10-13-2006 07:52 PM
Try these and let me/us know:
http://www.odometergears.com/
http://www.z3bimmer.com/OffTopic/E24Bimmer//OdoGear/
Wayne 962 10-15-2006 03:44 PM
Yes, we need to get these and the other gears into our catalog...
-Wayne
gejettest 10-16-2006 08:15 AM
Thanks Jeron,
I have to take it apart to give them the correct number of teeth of the existing gear, then order from there.
I'll be sure to post the results.
Henry
koya1893 10-16-2006 11:56 AM
Gentlemen, thank you for the info on the gear. I went through three or four use cluster from the junk yard and not even six mongths later I am faced with the Odometer not working until I found this site. Now my 1894 318i is alive again. Now I just need to find some bolt on power for it.
Ben
Wayne 962 10-16-2006 07:40 PM
Although Porsche-centric, check out this article on odometer repair:
http://www.pelicanparts.com/bmw/techarticles/Borrowed/mult_gauge_repair.htm
-Wayne
