325i 1992 wont start??
hey! after replacing the head gasket i took the car for a test drive and the car began misfiring, then when i got home after 5-6 miles and switched it off it wudnt start again, then relised i could hear no fuel pump working,ive crossed the relay and the pump is working ok and building presure,ive replaced all relays checked fuses and still same results?? and i replaced the ecu and still no good?? also ive hooked the car up too a computer and no fault codes are found in either of the two ecu's?? could i have timed the car wrong? wud it have drove so far without stopping?? please help!!
Old 10-30-2006, 02:38 PM
ps i forgot too mention its an m50 sorry!
Old 10-30-2006, 02:40 PM
