HEATER MOTOR REPLACEMENT 91 318i
Can the motor blower be replaced without removing the intake manifold?
Old 09-02-2006, 05:08 PM
Since my question about removing the manifold, I have found out you do have to remove the upper half of the intake manifold for the motor and fans to fit into the blower case.
When the old fans (plastic) disintegrated, it was easy for the motor to fit through the opening under the hood.
With the replacement motor and new fans attached, they wouldnt fit back through the opening, the upper part of the intake manifold was in the way.
The upper half of the manifold is an easy job to remove, But be very careful with the small coolant hoses that are hooked to the back of the throttle body.
Bentley book says to replace the intake manifold gasket, but mine was in good shape and has not been a problem.
Life is short, pay attention, pass on what you learned.
Old 11-04-2006, 05:06 PM
Author of "101 Projects"
Wayne 962's Avatar
Also dont' forget the heater core hose at the back of the cylinder head, if you need to disconnect it...
-Wayne
Old 11-12-2006, 02:22 PM
