Smile E36 Driver Window Motor
My window is stuck all the way down. Any idea how to test the motor, ie. apply current to the motor and try to get it to work?
I've been asked how many amps the motor take, and I've no clue.
Any suggestions?
Many thanks in advance
92E364DR25i
Old 06-15-2007, 11:28 AM
how about just check power to the motor. if there is power to the motor when switched and no noise from the motor then the motor is bad
gONe
Old 06-15-2007, 06:16 PM
Thanks very much for your reply. After I posted this, we did more checks. It was weird, but initially when I pressed the switch, there was a click in the motor. We took the plug off and did the checks and couldnt find a problem..but turns out fooling with the plug was the secret. When we put the plug back on, IT WORKS!
I should have known to check the connections, but the click was throwing me off.
A little embarrasing, but oh well........
Hope this helps others, and thanks again for your input.
92E364DR25i
Old 06-16-2007, 08:22 AM
