Speedometer failed; Odometer works
The speedometer on my '95 318i fails sometimes. It will fall to zero when it fails, but the odometer continues to operate correctly all the time.
I believe that the problem is not the speed sensor in the differential because the odometer works fine. Is this a good diagnosis? I found a site that offered replacment gears for speedometers for some BMW models, but it didn't specify which models so I was sceptical. What should I do? |
| All times are GMT -8. The time now is 10:43 AM. |
