E30 Wipers Inop
So, the rain started again here in the Northwest, and my wipers just quit working. The car is a 1984 325e. I pulled the wiper control module from the fuse box and placed a different one from my 1988 325is, and the wipers still do not work. Can anyone steer me to the next step in diagnosing the problem?
Thanks,
Bob
Old 02-15-2007, 06:51 PM
Bob,
Are all fuses and relays associated with your windshield wipers OK?
Old 02-16-2007, 06:04 AM
The 30 amp fuse is ok
1987 911 Guards Red Carrera (current project)
1988 BMW 325 iS (sold)
1989 325iX (winter blaster)
2013 VW Jetta TDI (civilized touring car)
1991 Saab SPG (sold)
Old 02-16-2007, 08:41 AM
Try pulling the module and checking for voltage on the +12 V contact with the ignition in accessory or on. If you don't get battery voltage, you've got a wiring problem. Then, try (with the module still removed) jumpering the terminals for fast/slow to the +12 V (make the connections with the ignition off, then turn on to check). If you don't get any motion, then it's either the motor or wiring to the motor.
If you did get the wipers moving, then it's prob the switch. Check that by using a multimeter from ground to each of the contacts (ignition off) with the switch in each position. The connection is under the steering column.
Old 02-16-2007, 09:47 AM
OK, This is helpful... thank you. The jump connectors work, so now I'm on to the switch... I'll be checking it soon. Thanks. Bob
Old 02-16-2007, 10:10 PM
OK, So using the Bentley manual, page 15-28, I checked the continuity of the ground wire, as shown in figure 8-4, using a multimeter. I got resistance, so I simply removed the screw and placed the washer behind the wire connector, then screwed it back tight. I then rechecked for resistance, and found there to be none!
Wipers work perfectly fine now! Simple as that.
Thanks for the help folks.
Bob
Old 02-18-2007, 02:49 PM
