-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Tach, temp gauge not working. (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/330001-tach-temp-gauge-not-working.html)
Jeff Nottingham 02-12-2007 10:04 AM
I have a 1987 325e and my tack and temp gauges are not working at all. But my speedo and fuel gauge is working. Where should I start looking. Fuses are ok.
Jeff
supertack 02-12-2007 11:43 AM
Someone had this identical problem last month.
Gages
Don't know how much help it's gonna be though.
razinswim 02-12-2007 12:24 PM
I had that problem three months ago. The problem was a broken electrical cable that goes very close to the shifter. The cable was in the way of the shifter and was cut in half. That is one possibility. I own a 1986 325es bmw. Today I fixed the sunroof!
onematd 02-27-2007 04:45 PM
Hello,
I have a 85 325e, and have had similar problems in the past. On both occasions I removed the instrument cluster, disassembled it, and re-flowed the cold solder joints. These solder joints will fail due to continuous heating and cooling. You can identify a cold joint by it's color. A proper joint should be nice and shiny with no pitting. A cold joint will be a dull gray color. You should also inspect closely for cracked solder joints. This corrected my malfunctioning speedo/tach when I first purchased the car, and my inop temp gauge less than a year ago.
